Einleitung
This guide will go over how to clean or replace the roller brushes in your iRobot Roomba 805. If you plan on replacing the roller brushes you can get a new one from iRobot. No tools are needed to follow this guide.
Was du brauchst
Start by squeezing the yellow levers on either side of the roller brush cage.
From the right side, push in and up to remove each roller.
Remove any stuck debris or replace with new clean rollers.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
