Was du brauchst
To remove the debris extractor, first begin by removing and emptying the trash bin.
Push down and pull out on the silver button located on the top of the Roomba in the back.
The trash bin should then slide out.
With the Roomba upside down, locate the two yellow buttons by the extractor.
To open the flap holding the extractos in place, pinch the two yellow buttons together towards the center and pull up on the flap at the same time
Once the flap is open, grab the yellow end of the dark gray extractor and pull up slightly.
After lifting it up about an inch, pull it out towards one of the side wheels.
The extractor should slide out with ease. Repeat the same procedure for the light gray debris extractor.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
