Zum Hauptinhalt wechseln
iRobot Roomba 860 Filter Replacement
  1. iRobot Roomba 860 Filter Replacement, Filter: Schritt 1, Bild 1 von 3 iRobot Roomba 860 Filter Replacement, Filter: Schritt 1, Bild 2 von 3 iRobot Roomba 860 Filter Replacement, Filter: Schritt 1, Bild 3 von 3
    • Orient the Roomba so that the device is on its wheels and the words can be read from left to right.
    • Press the large button on the Roomba that is located closest to you.
    • Pull towards you to remove dust bin.
    • Now place dust bin flat with the large button towards you.
  2. iRobot Roomba 860 Filter Replacement: Schritt 2, Bild 1 von 2 iRobot Roomba 860 Filter Replacement: Schritt 2, Bild 2 von 2
    • With the dust bin completely detached from the Roomba, press the tab that is located on your right.
    • Now lift red plastic cover to begin removing the filter.
  3. iRobot Roomba 860 Filter Replacement: Schritt 3, Bild 1 von 2 iRobot Roomba 860 Filter Replacement: Schritt 3, Bild 2 von 2
    • Using the yellow ribbon that is located at the top of the filter, pull it towards you.
    • Carefully remove the used filter.
Abschluss
Stephen Yezukevicz
193 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 Mitglied von UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G5
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 304
