Zum Hauptinhalt wechseln
iRobot Roomba 880 Cleaning Head Replacement
Was du brauchst
  1. iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: Schritt 1, Bild 1 von 3 iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: Schritt 1, Bild 2 von 3 iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: Schritt 1, Bild 3 von 3
    • Flip the Roomba over, wheel-side up.
    • Using a Phillips #1 screwdriver, loosen the four 15 mm screws illustrated. Two are located on the battery door, while two are on the bottom panel.
    • Remove the battery door, pulling straight up from the two indents above the screws.
  2. iRobot Roomba 880 Cleaning Head Replacement, Side Brush: Schritt 2, Bild 1 von 2 iRobot Roomba 880 Cleaning Head Replacement, Side Brush: Schritt 2, Bild 2 von 2
    • Using a flat head screwdriver, loosen the screw on the top of the side brush.
    • Remove side brush.
    • The bottom panel cannot be removed without first removing the side brush, so make sure to do this first.
  3. iRobot Roomba 880 Cleaning Head Replacement, Bottom Panel: Schritt 3, Bild 1 von 1
    • Pull up on the bottom panel to remove.
  4. iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: Schritt 4, Bild 1 von 2 iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: Schritt 4, Bild 2 von 2
    • Reach underneath the dust bin, press the bin removal button, and pull out.
    • The bin removal button is located on the top edge of the bin.
  5. iRobot Roomba 880 Cleaning Head Replacement: Schritt 5, Bild 1 von 2 iRobot Roomba 880 Cleaning Head Replacement: Schritt 5, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the four 10 mm screws shown.
  6. iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: Schritt 6, Bild 1 von 3 iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: Schritt 6, Bild 2 von 3 iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: Schritt 6, Bild 3 von 3
    • Remove the cleaning head by grabbing the two protruding tabs as shown, and pulling straight up.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Allie Ahern
130 Reputation
1 Anleitung geschrieben
Cal Poly, Team S17-G4, Banghart Spring 2017 Mitglied von Cal Poly, Team S17-G4, Banghart Spring 2017
CPSU-BANGHART-S17S17G4
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 2,235
