Einleitung
If the side brush on your Roomba 880 isn't spinning, it may need a new side brush motor. Here's how to replace it!
Was du brauchst
Remove the two Phillips #1 15mm screws holding the battery cover in place.
Once unscrewed, remove the battery cover and set aside.
Remove the 10mm Phillips #1 screw holding the side brush in place.
Once unscrewed, remove the side brush and set aside.
Remove the three 10mm Phillips #1 screws holding down the side brush motor case.
Remove the 10mm Phillips #1 screw holding down the lid of the side brush motor case.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
