Was du brauchst
Start with your Roomba upside down, with the wheels facing up.
Using a JIS driver in #1 size remove the two 15mm screws holding the battery cover in place.
Loosen the side brush screw with a screwdriver.
Remove the side brush
Loosen the single screws that retains the side wheel to the Roomba.
Remove cover over the wheel that was held in place by the screws.
Remove the wheel module.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
