Was du brauchst
Use a Phillips #2 screwdriver to remove the 7.7 mm screw.
Remove the yellow brush head.
Place the Roomba facedown, with its bottom facing you.
Use a Phillips #2 screwdriver to remove the two 11 mm screws.
Remove the battery plate.
Remove the battery by pulling directly up on the grey pull tabs.
Use a Phillips #2 screwdriver to remove the four 11 mm screws.
Remove the bottom plate of the Roomba.
Turn Roomba face up.
Remove the dustbin by pressing the release button on the top side of the Roomba and pulling it straight out.
Using the opening tool, remove retaining band.
Use the removal tool to remove the face plate as well.
Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
Lift the top plate off.
Locate the charging contact wire connection to the motherboard.
Release the connector.
Use a Phillips #1 screwdriver to remove the two 9.3 mm screws holding the charging contact backings in place.
Remove the charging contact backings.
Use the iFixit opening tool to gently pry down on the charging contact, on the side closest to the cliff sensor.
With the charging contact dislodged, pull it through the Roomba housing.
2 weitere Personen haben diese Anleitung absolviert.
