Zum Hauptinhalt wechseln
iRobot Roomba 890 IR Sensor Replacement
Was du brauchst
  1. iRobot Roomba 890 IR Sensor Replacement, IR sensor: Schritt 1, Bild 1 von 1
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
    • Remove the battery cover.
  2. iRobot Roomba 890 IR Sensor Replacement: Schritt 2, Bild 1 von 2 iRobot Roomba 890 IR Sensor Replacement: Schritt 2, Bild 2 von 2
    • Pull directly up on the grey pull-tabs to remove the battery.
  3. iRobot Roomba 890 IR Sensor Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #2 screwdriver to remove the one 7.7 mm screw.
    • Remove the yellow brush head.
  4. iRobot Roomba 890 IR Sensor Replacement: Schritt 4, Bild 1 von 3 iRobot Roomba 890 IR Sensor Replacement: Schritt 4, Bild 2 von 3 iRobot Roomba 890 IR Sensor Replacement: Schritt 4, Bild 3 von 3
    • Use a Phillips #2 screwdriver to unscrew the two 11 mm screws.
    • Lift the baseplate up and off.
  5. iRobot Roomba 890 IR Sensor Replacement: Schritt 5, Bild 1 von 2 iRobot Roomba 890 IR Sensor Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the ten 9.3 mm screws.
    • Remove the bumper retainer ring.
  6. iRobot Roomba 890 IR Sensor Replacement: Schritt 6, Bild 1 von 2 iRobot Roomba 890 IR Sensor Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the two 7.5 mm screws holding the IR sensor in place.
  7. iRobot Roomba 890 IR Sensor Replacement: Schritt 7, Bild 1 von 2 iRobot Roomba 890 IR Sensor Replacement: Schritt 7, Bild 2 von 2
    • Use an iFixit opening tool to remove the outer plastic covering from the top of the Roomba.
  8. iRobot Roomba 890 IR Sensor Replacement: Schritt 8, Bild 1 von 3 iRobot Roomba 890 IR Sensor Replacement: Schritt 8, Bild 2 von 3 iRobot Roomba 890 IR Sensor Replacement: Schritt 8, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handlebar screws; then remove the handle.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift off the top plate.
  9. iRobot Roomba 890 IR Sensor Replacement: Schritt 9, Bild 1 von 3 iRobot Roomba 890 IR Sensor Replacement: Schritt 9, Bild 2 von 3 iRobot Roomba 890 IR Sensor Replacement: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    • Use a pair of angled tweezers to firmly grip the IR sensor plug, and pull it directly backwards to release it from the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 1-3, Petersen Spring 2022 Mitglied von UMass Dartmouth, Team 1-3, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G3
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 26
Insgesamt: 1,322
