Zum Hauptinhalt wechseln
iRobot Roomba 891 Battery Replacement
Was du brauchst
  1. iRobot Roomba 891 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 iRobot Roomba 891 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Battery Replacement: Schritt 2, Bild 1 von 1
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Battery Replacement: Schritt 3, Bild 1 von 3 iRobot Roomba 891 Battery Replacement: Schritt 3, Bild 2 von 3 iRobot Roomba 891 Battery Replacement: Schritt 3, Bild 3 von 3
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
justin i added a push pin to step 1
thomas Wilson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 822
