Einleitung
This guide will walk you through the required steps to replace the roomba battery. Including all required tools and a link for the replacement battery.
Was du brauchst
Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
Grasp the tabs on either side of the battery.
Remove the battery by pulling up on the tabs.
While you're here, check the battery contacts for corrosion or debris.
2 weitere Personen haben diese Anleitung absolviert.
