Einleitung
This guide will help you replace the drive wheels on your roomba. This guide highlights the ease of repairability of the roomba and the modular design of this model. The wheels are side specific and sold in pairs. Modules can be purchased at the links included.
Was du brauchst
Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
Grasp the tabs on either side of the battery.
Remove the battery by pulling up on the tabs.
While you're here, check the battery contacts for corrosion or debris.
Remove 2 Phillips #2 11mm screws from the bottom cover.
Remove the bottom cover.
Ein Kommentar
justin i added the word captive to the steps where the screws stayed in place
