Einleitung
This easy guide show you the steps to remove and replace the extractor assembly on your roomba.
Was du brauchst
Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
Grasp the tabs on either side of the battery.
Remove the battery by pulling up on the tabs.
While you're here, check the battery contacts for corrosion or debris.
Close the cover and remove the four 11mm Phillips #00 screws from the assembly.
