Einleitung
This easy to follow guide will walk you through replacing a defective side brush module on your roomba. This guide requires a propriatery bit screwdriver that is not found in most homes. You will need to purchase one before begining.
Was du brauchst
Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
Grasp the tabs on either side of the battery.
Remove the battery by pulling up on the tabs.
While you're here, check the battery contacts for corrosion or debris.
Unscrew and remove the single 13mm Tri-point Y1 screw and retaining tab.
Loosen two captive Phillips #00 16mm screws.
