Einleitung
This guide will instruct you how to replace the debris extractors in the iRobot Roomba 960.
Was du brauchst
Turn the Roomba upside down and orient it so that the wheels are facing upwards and the dustbin is furthest from you.
Pinch the two yellow tabs that are located near the dustbin towards each other to open the frame.
Carefully apply pressure to one side of the first debris extractor to release it. Lift to remove.
Do the same to the second debris extractor.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
