Zum Hauptinhalt wechseln
iRobot Roomba 980 Brush Module Replacement
Was du brauchst
  1. iRobot Roomba 980 Brush Module Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
  2. iRobot Roomba 980 Brush Module Replacement: Schritt 2, Bild 1 von 2 iRobot Roomba 980 Brush Module Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the back plate using a Phillips #1 screwdriver.
    • Carefully lift the panel up once the screws are removed.
  3. iRobot Roomba 980 Brush Module Replacement: Schritt 3, Bild 1 von 2 iRobot Roomba 980 Brush Module Replacement: Schritt 3, Bild 2 von 2
    • With both hands, grab the two black tabs on each end of the battery.
    • Pull the tabs upwards to remove the battery.
  4. iRobot Roomba 980 Brush Module Replacement, Brush Module: Schritt 4, Bild 1 von 3 iRobot Roomba 980 Brush Module Replacement, Brush Module: Schritt 4, Bild 2 von 3 iRobot Roomba 980 Brush Module Replacement, Brush Module: Schritt 4, Bild 3 von 3
    • Press down on the button on the rear of the device.
    • Pull bin towards you to remove it.
  5. iRobot Roomba 980 Brush Module Replacement: Schritt 5, Bild 1 von 2 iRobot Roomba 980 Brush Module Replacement: Schritt 5, Bild 2 von 2
    • Loosen the screw holding the side brush in place.
    • The screw is attached to the side brush and does not come out completely.
    • Lift the side brush.
  6. iRobot Roomba 980 Brush Module Replacement: Schritt 6, Bild 1 von 2 iRobot Roomba 980 Brush Module Replacement: Schritt 6, Bild 2 von 2
    • Remove the (2) 11.5mm Phillips #1 screws holding down the bottom plate.
    • Carefully lift the bottom plate.
  7. iRobot Roomba 980 Brush Module Replacement: Schritt 7, Bild 1 von 1
    • Remove the (4) 15.8mm Phillips #1 gold screws around the brush module.
  8. iRobot Roomba 980 Brush Module Replacement: Schritt 8, Bild 1 von 2 iRobot Roomba 980 Brush Module Replacement: Schritt 8, Bild 2 von 2
    • Lift the brush module carefully using both hands.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S14-G2, Boczar Fall 2017 Mitglied von USF Tampa, Team S14-G2, Boczar Fall 2017
USFT-BOCZAR-F17S14G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 50
Insgesamt: 4,739
