Einleitung
If all efforts to repair the Roomba® 980 vacuum fail, replacing its motherboard is usually the last step before a full resolution is achieved. There can be several reasons why this replacement is necessary, from water to physical damage, the process can be a complicated, lengthy installation. Finally, proceed with caution when handling the circuit board’s connectors and pins as damaging this can result in irreparable damage.
Was du brauchst
Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
Unscrew the back plate using a Phillips #1 screwdriver.
Carefully lift the panel up once the screws are removed.
With both hands, grab the two black tabs on each end of the battery.
Pull the tabs upwards to remove the battery.
Remove the dust bin by pressing down on the rear button on the device.
Pull the bin towards you to remove it.
Insert the opening tool in the back of the device under the wedge.
Slowly pry the plate loose and lift it from the device.
Loosen the screw holding the side brush in place, by using a Phillips #1 screwdriver
Lift the side brush.
Remove the two 11.5mm screws holding down the bottom plate using a Phillips #1 screwdriver
Carefully lift the bottom plate.
Remove the four 15.8mm gold screws around the brush module using the Phillips #1 screwdriver.
Lift the brush module carefully using both hands.
Remove the three 15.8mm gold screws with a Phillips #1 screwdriver.
Lift the wheel module to remove it from the vacuum.
Remove the other wheel by repeating these steps.
Remove the ten 6.1 mm silver screws using a Phillips #1 screwdriver.
Lift the bottom guard off the front sensor panel by pulling it upwards.
Lift the two corner guards at the rear of the device by lifting and popping them out.
Pull the front sensor away slowly from the vacuum.
Flip the sensor over and use a Phillips #1 screwdriver to remove the two 3.8 mm silver screws that hold the sensors to the panel.
Once removed, pull the panel away carefully.
Remove the fourteen 6.6 mm black screws holding down the top plate using a Phillips #1 screwdriver.
Push the lip back towards the logo to remove two 6.6 mm black screws found under it using a Phillips #1 screwdriver.
Lift the top plate slowly, being careful not to damage the vacuum components while exposing the motherboard.
Remove the nine 6.4 mm silver screws holding the motherboard to the vacuum body and the clear plastic guard using a Phillips #1 screwdriver.
Carefully remove the connector-clips that are attached to the motherboard.
Using both hands, lift the motherboard connected to the camera away from the device's main motherboard.
Remove the black plastic guard that is placed in between the two computer boards
Lift the main motherboard upward and off of the vacuum.
Remove the motherboard from your device.
21 weitere Nutzer:innen haben diese Anleitung absolviert.
9 Kommentare
Thank you for the replacement instructions & pictures…so helpful!
Any idea where I can purchase a roomba 980 motherboard?
Where can I purchase the roomba 980 motherboard?
aliexpress my friend
you don’t need to take out the modules to take out the circuit board
If you find a rectangular rubber grommet left over when you’ve finished, it goes in a slot behind the dust bin and you can reinsert it from the outside just by removing the bin first.
