Einleitung
The rear wheel assembly is what propels the roomba. If they become damaged the roomba will begin to move irregularly or not at all.
Was du brauchst
Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
Unscrew the back plate using a Phillips #1 screwdriver.
Carefully lift the panel up once the screws are removed.
With both hands, grab the two black tabs on each end of the battery.
Pull the tabs upwards to remove the battery.
Loosen the screw on the side brush.
Lift the side brush from the device.
Unscrew the (2) 11.5mm screws using the Phillips #1 screwdriver.
Carefully remove the plate by lifting it off of the device.
Locate the (3) 15.8mm gold Phillips #1 screws and unscrew them.
Lift the wheel module removing it from the vacuum.
Remove the other wheel by repeating these steps.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
