Zum Hauptinhalt wechseln
iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement
  1. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement, Home Base Vacuum Bag: Schritt 1, Bild 1 von 1
    • Open the vacuum bag container at the top of the home base.
  2. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: Schritt 2, Bild 1 von 3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: Schritt 2, Bild 2 von 3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: Schritt 2, Bild 3 von 3
    • Grab the grey tab at the top of the bag and lift the bag straight out of the home base.
Abschluss
Cal Poly, Team S18-G3, White Winter 2020 Mitglied von Cal Poly, Team S18-G3, White Winter 2020
CPSU-WHITE-W20S18G3
4 Mitglieder
9 Anleitungen geschrieben
2 Kommentare
what do you do if after you change the bag , the base says there is no bag? So I replaced the old bag after I pulled stuff out , still no change. now robot won’t work . On app it says end job stuck and all it did is move off base and turn around (after hit clean) help
shelleyandboys - Antwort
Can we have a tear down of the base? The bag switch sometimes doesn't want to work properly. You can resolder a new switch or just solder a jumper so it always "senses" one. There's alot of screws, sensors, wires and a big motor. It helps to know where all the screws go.
ashimo0463 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 1,417
