Einleitung
Use this guide to replace the right wheel module on your iRobot Roomba S9 Plus. Know that the left and right wheel replacement processes are unique.
Was du brauchst
Press the plastic hook under the lid.
Lift the handle and remove the bin.
Flip over the Roomba.
Loosen, but do not remove, the eight screws on the bottom using a Phillips #2 screwdriver.
Using your spudger, press the latch on the inside of the wheel module.
Remove the wheel module.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
