Zum Hauptinhalt wechseln
iRobot Roomba e5 Maintenance
Was du brauchst
  1. iRobot Roomba e5 Maintenance, Two middle brushes, Edge Sweeping Brush and Dust Bin: Schritt 1, Bild 1 von 3 iRobot Roomba e5 Maintenance, Two middle brushes, Edge Sweeping Brush and Dust Bin: Schritt 1, Bild 2 von 3 iRobot Roomba e5 Maintenance, Two middle brushes, Edge Sweeping Brush and Dust Bin: Schritt 1, Bild 3 von 3
    • To remove the edge sweeping brush, use a Phillips #0 screwdriver to remove the 8 mm screw holding it in place.
  2. iRobot Roomba e5 Maintenance: Schritt 2, Bild 1 von 3 iRobot Roomba e5 Maintenance: Schritt 2, Bild 2 von 3 iRobot Roomba e5 Maintenance: Schritt 2, Bild 3 von 3
    • To remove the two multi-surface brushes, lift the adjacent piece by pressing down the green lever and pulling it up.
    • Then remove the brushes by lifting them by the right side.
  3. iRobot Roomba e5 Maintenance: Schritt 3, Bild 1 von 1
    • To remove the dust bin, press down on the button with a “trash bin” drawing by the side of the vacuum.
    • While pressing the button, gently pull the dust bin out.
    • When removing the dust bin, dust can tip over the surface and create a mess.
  4. iRobot Roomba e5 Maintenance: Schritt 4, Bild 1 von 2 iRobot Roomba e5 Maintenance: Schritt 4, Bild 2 von 2
    • To remove the filter located at the right side of the dust bin, press the filter on top and at the bottom and pull.
  5. iRobot Roomba e5 Maintenance: Schritt 5, Bild 1 von 3 iRobot Roomba e5 Maintenance: Schritt 5, Bild 2 von 3 iRobot Roomba e5 Maintenance: Schritt 5, Bild 3 von 3
    • Clean every part of the vacuum thoroughly with a dust rag or paper towel and Q-tip.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 34
Insgesamt: 1,480
