Zum Hauptinhalt wechseln
iRobot Roomba i3 Plus Battery Replacement
Was du brauchst
  1. iRobot Roomba i3 Plus Battery Replacement, The Cover: Schritt 1, Bild 1 von 1
    • Unscrew the 5 #0 Phillips screws.
    • The screws do not come out all the way, they will stay in the cover.
  2. iRobot Roomba i3 Plus Battery Replacement, The Brush: Schritt 2, Bild 1 von 1
    • Use a Flathead screwdriver or Philips to unscrew the side brush.
    • Make sure to hold the side brush or it will spin when you try to unscrew it.
  3. iRobot Roomba i3 Plus Battery Replacement, Remove cover: Schritt 3, Bild 1 von 1
    • Gently pull the side brush straight up.
    • Do not pull the side brush too hard or you may break the plastic.
  4. iRobot Roomba i3 Plus Battery Replacement: Schritt 4, Bild 1 von 1
    • Use your fingernails to pull up on each side to remove the cover.
    • If there is resistance, Do not pull hard, just find what screw is not all the way unscrewed.
  5. iRobot Roomba i3 Plus Battery Replacement: Schritt 5, Bild 1 von 1
    • Pull back the clip in the middle and pull the battery straight up.
    • When assembling the Roomba again. put the robot on its charging base to wake it up.
  6. iRobot Roomba i3 Plus Battery Replacement: Schritt 6, Bild 1 von 1
    • Line the battery up with the notches and side it in.
Abschluss
To reassemble your Roomba, follow these instructions in reverse order.
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 44
Insgesamt: 773
