Einleitung
This guide will show you how to remove the auger, and how to replace the part that connects the auger to the motor.
Was du brauchst
To remove the auger simply pull it off
Then unscrew the four screws holding the plastic part in place
You can then pull that off revealing the piece that connects to the motor
The metal piece can now be replaced by inserting a new one
Fast fertig!
Abschluss
