Zum Hauptinhalt wechseln
iRobot looj 120 Rear Motor Replacement
Was du brauchst
  1. iRobot looj 120 Rear Motor Replacement, Rear Motor: Schritt 1, Bild 1 von 1
    • Remove the four exterior screws
Abschluss
Joshua
631 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Yeah, to replace the motor just 4 screws and no parts required! Too easy, too easy to write an article that doesn’t help :( Is it just to sell a screwdriver? This would not improve your reputation. You’re wasting our time and wasting your time.
Description: Remove the 4 screws than anyone can see is a good start but did anyone been able to actualy open the body and access inside the box?
I do have an iRobot Looj 330. The body looks very similar to the other model in the range. There are 4 screws, yes but the body in 2 parts doesn’t open that easy. It’s waterproof, I believe there is a trick… Which?
Daniel B - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 249
