Zum Hauptinhalt wechseln
iView-776TPCII Rear Panel Replacement
Was du brauchst
  1. iView-776TPCII Rear Panel Replacement, Rear Panel: Schritt 1, Bild 1 von 3 iView-776TPCII Rear Panel Replacement, Rear Panel: Schritt 1, Bild 2 von 3 iView-776TPCII Rear Panel Replacement, Rear Panel: Schritt 1, Bild 3 von 3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
  2. iView-776TPCII Rear Panel Replacement: Schritt 2, Bild 1 von 2 iView-776TPCII Rear Panel Replacement: Schritt 2, Bild 2 von 2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
IUPUI, Team 2-2, Baechle Fall 2015 Mitglied von IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 61
Insgesamt: 641
