Zum Hauptinhalt wechseln
iView-776TPCII Rear Panel Replacement
Was du brauchst
  1. iView-776TPCII Rear Panel Replacement, Rear Panel: Schritt 1, Bild 1 von 3 iView-776TPCII Rear Panel Replacement, Rear Panel: Schritt 1, Bild 2 von 3 iView-776TPCII Rear Panel Replacement, Rear Panel: Schritt 1, Bild 3 von 3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
  2. iView-776TPCII Rear Panel Replacement: Schritt 2, Bild 1 von 2 iView-776TPCII Rear Panel Replacement: Schritt 2, Bild 2 von 2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
Abschluss
IUPUI, Team 2-2, Baechle Fall 2015 Mitglied von IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 326
