Was du brauchst
Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
Remove the battery cover by gently pushing inward on the arrow on the cover.
While maintaining pressure push the cover upward.
The SD Card slot is located under the battery case indicated here.
The SD Card Slides into the slot as depicted in the photo and on the indicator above the slot.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
