Zum Hauptinhalt wechseln
Werkzeuge
Keine Werkzeuge angegeben.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack. Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
    • Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
  2. Remove the battery cover by gently pushing inward on the arrow on the cover. While maintaining pressure push the cover upward. While maintaining pressure push the cover upward.
    • Remove the battery cover by gently pushing inward on the arrow on the cover.
    • While maintaining pressure push the cover upward.
  3. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  4. Remove the Battery from the socket When installing the battery take note of the signs displayed in the socket to determine which direction the negative and positive ends should be.
    • Remove the Battery from the socket
    • When installing the battery take note of the signs displayed in the socket to determine which direction the negative and positive ends should be.
  5. The SD Card slot is located under the battery case indicated here. The SD Card Slides into the slot as depicted in the photo and on the indicator above the slot.
    • The SD Card slot is located under the battery case indicated here.
    • The SD Card Slides into the slot as depicted in the photo and on the indicator above the slot.
    • The ilo 1Gb Mp3 Player was only designed to accept SD Cards of 512mb or lower.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
tjkurt01
306 Reputation
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 274
