Zum Hauptinhalt wechseln
ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement
  1. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement, Front Wheel (Swivel Caster): Schritt 1, Bild 1 von 1
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Flip your ionvac upside down so the wheels are pointed upwards.
  2. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: Schritt 2, Bild 1 von 2 ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: Schritt 2, Bild 2 von 2
    • Using your thumb and forefinger, grip the flat sides of the wheel and pull it out.
    • If the wheel is stuck, you can use a spudger to pry the caster out.
    • When reinstalling, the wheel should click into place. Before restarting the ionvac, try spinning the wheel with your finger to test its movement.
Abschluss
Ruth Mekonnen
737 Reputation
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 66
