Zum Hauptinhalt wechseln
ionvac SmartClean V2 Shell (Top & Bottom) Replacement
Was du brauchst
  1. ionvac SmartClean V2 Shell (Top & Bottom) Replacement, Shell (Top & Bottom): Schritt 1, Bild 1 von 2 ionvac SmartClean V2 Shell (Top & Bottom) Replacement, Shell (Top & Bottom): Schritt 1, Bild 2 von 2
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
  2. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: Schritt 2, Bild 1 von 3 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: Schritt 2, Bild 2 von 3 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
  3. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: Schritt 3, Bild 1 von 1
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
  4. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: Schritt 4, Bild 1 von 2 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: Schritt 4, Bild 2 von 2
    • Lift the top shell off carefully.
Abschluss
Ruth Mekonnen
737 Reputation
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 67
