Was du brauchst
rotate ear cushion 45 degree counter clockwise to release it.
remove black adhesive pad located on top of the phillips screw shown on image (use scalpel)
unscrew the screw
lift up speaker module. note metal swivel can be removed.
leave speaker module in place - carefully because of short length wires for speaker module.
unscrew 5 pcs phillips screws.
note the bump on the shell is located right by the jack cable entry.
battery side now visible and can be repaired and inspected.
the USB charger board can be removed with one phillips screw
note there is a small lightguide attached to USB board. Note how is is located if removing it.
To remove the glue on the soldered wires, add alcohol to it first. This will make it hard, and easy to remove. In order to check solderings. (often seen issue that hand soldering are faulty)
4 weitere Nutzer:innen haben diese Anleitung absolviert.
18 Kommentare
Any idea how to fix the microphone mute switch? Mine has failed, with the microphone always on mute. There is a small bit of static as the microphone is raised or lowered.
The switch for the microphone is connected to MU_SW on the board and is screwed with a philips screw. I unscrewed it and left it like this as the button mutes when the small black button is pressed. It was a mechanical problem that left it muted all the time. Now it works! I lost the functionality to mute when pulling the mic up but I dont mind!
Hope this helps anyone who finds this
Marcel -
Hi Malcolm, I know it is a micro switch . I believe it is on the inside of the earcup - you can inspect it when open. Remember to check with multimeter the wire soldering - it might be the cable to pcb soldering and not the switch. remember Alcohol is usefull to add onto the glue before removal. so you can inspect and measure. good luck
The micro switch works OK but the mechanics of the ring slider for the micro carrier has too much play. I got cutouts for the microphone.
Solution: disassemble the micro switch carrier PCB as described above; the swich know stays out like a triangle. Carefully remove the triangle (it is clamped into the housing with 2 sideways plastic studs) with a forceps (it comes out with a flimsy metal tongue), put it on a plain area and remove the top of the triangle with a cutter knife.
The reassembly is difficile though…
My wire is corrupted. I have a replacement. Am I better off cutting the wire from the middle and solder each of the small wires and shrink wrap or solder the whole wire from where it is connected in ear piece ? Any idea on what strategy to use for soldering if I have the full wire (i got a replacing set from a cheap used headset from ebay and the wire is ok in it)
My wire is corrupted cause wires are loose at the 3.5 connector side. I tried soldering them with new head but they got loose after a week.
