Was du brauchst
First ensure your laptop is turned off and check if you have the necessary tools
All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
With the opening tool, remove a rubber foot.
For this action you will have to exert some force, because the foot is glued with a resistant glue.
Remove all screws with a Philips screwdriver PH1
All screws are the same so don't worry about identifying them.
With the plastic tool, insert between the plastics and gently pry open.
With your fingers continue to force open the bottom cover on the side indicated in the figure.
You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
To close the laptop just follow this guide in reverse.
Be careful to don't touch if not necessary any electrical part of the product and insure you're properly grounding.
Disconnect the cable marked in the figure gently, pulling it out of the connector.
Gently remove the battery.
CAUTION!!
Some products may have this battery fixed with double-sided adhesive tape. In these cases, use a wide spatula to remove the battery without bending it.
SAFETY WARNING!
Never bend or puncture the battery. Danger of explosion. If you detect a swollen or damaged battery, handle it with extreme care and place it in a protective container.
After remove the battery, you need to remove the black mylar that covers keyboard connector.
After removing the adhesive tape covering the connector, use the plastic tool to carefully lift the black component that locks the keyboard tape.
Then gently pull the keyboard cable and release it.
Follow the same procedure as to disconnect the keyboard flat cable for the cabe attached to the I/O board.
Under the I/O board there's a hole that you need to insert a tool and push the keyboard at the same time you pull the plastic as show in the picture. This plastic holds the keyboard.
There are more holders, but you just need to open one, the others will sag when you pull the keyboard smoothly
Finally the keyboard is detached. When assemble the new keyboard do all this procedure in reverse order, taking extra care to don't touch the cable contacts, or bend them.
Eine weitere Person hat diese Anleitung absolviert.
