Einleitung
You must first follow the instructions on how to open the device before proceeding with these instructions.
Pay attention to the precautions mentioned in the guide.
Was du brauchst
First make sure the notebook is turned off and check if you have the necessary tools.
All screws are identified by circles. Pay special attention to the red circles as the rubber covers hide the screws.
With an utlility knife remove all the screw covers.
For this action, the procedure must be carried out with caution, as the covers are glued with a resistant glue.
Remove all screws with a Philips PH1 screwdriver
All screws are the same, don't worry about identifying them.
Using the plastic tool, insert it between the plastic and open it carefully.
You will feel and hear several clicks, which are perfectly normal. Remove the rear LCD Cover completely.
Unscrew both hinges.
Carefully disconnect the cable identified in the figure, removing it from its connector.
Peel off and remove the Wireless antennas
Before removing the wireless antennas, the cable route must always be analyzed to ensure that the antennas will be correctly replaced in their original position.
Remove the LCD from the Bezel.
To reassemble the LCD module, you must perform the previous steps in reverse.
After replacing the LCD, always check if flat cable is correctly connected and the protection tape is stuck in the original position.
Eine weitere Person hat diese Anleitung absolviert.
100%
Miguel Santos hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
