Einleitung
After two years of use the whisk of our milk frother turned only slowly. It could be stopped with one finger. I found an instruction that suggested to change the polarity of the motor by exchanging the connection cables. This worked with our two milk frothers.
Was du brauchst
Remove the three screws with a screwdriver PH2
There is a little triangle impressed in the bottom plate to show the position of the on-switch.
Pull the bottom plate as far away from the housing as possible.
A red and a blue cable connect the motor and a plug. Pull out the plug from the circuit board.
On one side of the plug you see two slots. You can see the cable shoes in there.
With something pointed (eg. watchmaker's screwdriver) you press in one slot to open the cable shoe's locking catch. At the same time you pull on the cable.
Do the same with the second cable.
Exchange the position of the cables and push the cable shoes back in the plug.
The milk frother is re-assambled in reverse order.
Plug in the device, fill in some liquid an press the "cold foam" button. Now the motor should turn again. At the first time it might be necessary to give a little push by hand. The motor speed increases fast and remains.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
John Maier hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Ein Kommentar
Bei unserem bauähnlichen Milchschäumer Petra ließ sich das gleiche Problem genauso beheben.
