Zum Hauptinhalt wechseln
nikon s3700 LCD Display Screen Replacement
Was du brauchst
  1. nikon s3700 LCD Display Screen Replacement, Removing the Screws: Schritt 1, Bild 1 von 3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: Schritt 1, Bild 2 von 3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: Schritt 1, Bild 3 von 3
    • group screws according to color code.
    • Remove exterior screws
  2. nikon s3700 LCD Display Screen Replacement, Replace LCD: Schritt 2, Bild 1 von 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: Schritt 2, Bild 2 von 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: Schritt 2, Bild 3 von 3
    • Remove Rear casing.
    • With a thin blade, gently lift the top tight hand side of the buttons board releasing a peg from a hole on the midframe below. Whilst doing so, gently push on the top left hand side in order to release the buttons board from a clip. At the same time, the bottom left hand corner wil be released from another clip.
    • Flip over rear buttons board to expose LCD ZIF clamp.
    • Flip open the clamp of the ZIF connector and slide the ribbon cable out. (The connector may have a piece of sticky tape over it. Removing this may well open the connector clamping bar.)
    • The ZIF clamp is very fragile so please use caution when releasing the ZIF clamp. It breaks easily.
    • Remove the LCD.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 366
