Einleitung
This is a quick video of how to replace the battery and some of the challenges you will see, what tools you will need, and how easy it is to change it. I made a mistake that you can avoid.
Was du brauchst
Einführungsvideo
separate rubber case from back of earpiece. you don't need to remove it completely like I did.
rotate the back away from the case. its basically glued in place with no other fasteners
you will need to slowly cut through the foam to separate the wires from the battery. then use a soldering iron to desolder the old battery from the board these connections go through the entire board.
solder the new battery in and test the charging before reassembly.
the new battery I ordered was slightly larger but it fit with no problems. I found the wires inside this device to be fairly robust and did not have any issues with wires breaking or dislodging.
When I re-assembled I used small amounts of gorilla glue for both the case and the rubber cover. it worked very well and has worked well since. for more details I put together a short video you can check out.
5 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
I accomplished this battery replacement. I was successful. However in my opinion, this device was not meant to have this repair done. It is a “fiddley” affair, but possible. I think it took me two hours, at my leisure. Probably better off replacing the device. Unless…. your just that type who enjoys fiddling around.
