Einleitung
This guide shows you how to remove the optical drive from the laptop
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Flip laptop over and locate the battery release button
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. With the bottom of the laptop facing up and the front toward you locate and loosen the M2.5×9.0 captive screw holding the optical drive into the laptop.
    • With the bottom of the laptop facing up and the front toward you locate and loosen the M2.5×9.0 captive screw holding the optical drive into the laptop.
    • Insert a flat-bladed screwdriver or similar tool into the optical drive tab access hole and press the tab to the left to release the optical drive from the computer
    • The optical drive will unlock and pop out of the side of the laptop. You are now able to temove the optical drive from the laptop.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Richdave
Mitglied seit 09.04.2010
28.838 Reputation
30 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
279 Mitglieder
778 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 3,577
