Zum Hauptinhalt wechseln
ring Indoor Cam Speaker Replacement
Was du brauchst
  1. ring Indoor Cam Speaker Replacement, Body: Schritt 1, Bild 1 von 3 ring Indoor Cam Speaker Replacement, Body: Schritt 1, Bild 2 von 3 ring Indoor Cam Speaker Replacement, Body: Schritt 1, Bild 3 von 3
    • Place the cam with the base facing towards you.
    • Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
    • Remove the base from the rest of the camera.
  2. ring Indoor Cam Speaker Replacement: Schritt 2, Bild 1 von 2 ring Indoor Cam Speaker Replacement: Schritt 2, Bild 2 von 2
    • Place the cam with the top facing toward you.
    • Insert the iFixit opening pick into the crease at the top of the camera.
    • Slide the pick along the crease until you can separate the top cover of the camera from the backing.
    • Leave the pick in the crease.
  3. ring Indoor Cam Speaker Replacement: Schritt 3, Bild 1 von 2 ring Indoor Cam Speaker Replacement: Schritt 3, Bild 2 von 2
    • Place the camera on its side where the horizontal crease is facing you.
    • Insert another iFixit opening pick into the crease between the front and back portions of the camera.
  4. ring Indoor Cam Speaker Replacement: Schritt 4, Bild 1 von 3 ring Indoor Cam Speaker Replacement: Schritt 4, Bild 2 von 3 ring Indoor Cam Speaker Replacement: Schritt 4, Bild 3 von 3
    • Slide the pick along the vertical crease until you can remove the back cover of the cam, using the opening tool to pry the portions apart.
    • You may hear a popping noise when you pry it open.
  5. ring Indoor Cam Speaker Replacement, Motherboard: Schritt 5, Bild 1 von 3 ring Indoor Cam Speaker Replacement, Motherboard: Schritt 5, Bild 2 von 3 ring Indoor Cam Speaker Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Gently remove the three white leads from their sockets on the top of the motherboard.
  6. ring Indoor Cam Speaker Replacement: Schritt 6, Bild 1 von 2 ring Indoor Cam Speaker Replacement: Schritt 6, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the two 4.7 mm black screws located in the corners of the motherboard.
    • Using a Phillips #00 screwdriver, remove the two silver 5 mm screws in the center of the motherboard.
  7. ring Indoor Cam Speaker Replacement: Schritt 7, Bild 1 von 3 ring Indoor Cam Speaker Replacement: Schritt 7, Bild 2 von 3 ring Indoor Cam Speaker Replacement: Schritt 7, Bild 3 von 3
    • Use the iFixit opening pick to pry the motherboard from the body of the camera.
  8. ring Indoor Cam Speaker Replacement: Schritt 8, Bild 1 von 2 ring Indoor Cam Speaker Replacement: Schritt 8, Bild 2 von 2
    • Detach the black wire connecting the motherboard to the body of the camera.
  9. ring Indoor Cam Speaker Replacement, Speaker: Schritt 9, Bild 1 von 3 ring Indoor Cam Speaker Replacement, Speaker: Schritt 9, Bild 2 von 3 ring Indoor Cam Speaker Replacement, Speaker: Schritt 9, Bild 3 von 3
    • Gently remove the speaker using the spudger.
Abschluss
John Bray
411 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 123
