Einleitung
This guide shows how to remove and replace an inner tube of a tire. This process may difficult he first time it is attempted.
Was du brauchst
Remove the flat tire by loosening and removing the axle nut with a 19 mm wrench.
Unscrew the axle bolt with a 19 mm socket wrench.
Remove the axle bolt from hole and remove the wheel from the wheelchair.
Insert the 19 mm socket wrench between the rubber tire and the metal frame.
Carefully run the 19 mm socket wrench along the edge of the tire all the way around and bend the wrench down to pop the tire out of the rim.
Reach inside the tire and remove the tube from the metal frame.
Working all around the tire, carefully push the tube back into place inside the tire.
Finally, push the tire back into place on the metal frame and inflate the tire.
Insert the axle bolt into center of rear wheel.
Insert the wheel with the axle bolt into the lower back of the frame.
Screw the bolt on the outside of the wheel with a 19 mm socket wrench.
Screw the nut on the inside of the wheel with a 19 mm wrench.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
