Zum Hauptinhalt wechseln
the Nokia 6230b Speaker Replacement
Was du brauchst
  1. the Nokia 6230b Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Press down the button on the back panel.
  2. the Nokia 6230b Speaker Replacement: Schritt 2, Bild 1 von 2 the Nokia 6230b Speaker Replacement: Schritt 2, Bild 2 von 2
    • Push the back cover upwards.
  3. the Nokia 6230b Speaker Replacement: Schritt 3, Bild 1 von 2 the Nokia 6230b Speaker Replacement: Schritt 3, Bild 2 von 2
    • Remove the back cover from the phone.
  4. the Nokia 6230b Speaker Replacement, Front Cover: Schritt 4, Bild 1 von 1
    • Press the silver button on the top of the phone.
  5. the Nokia 6230b Speaker Replacement: Schritt 5, Bild 1 von 1
    • Slide your thumbnail down the case seam to separate the rest of the case.
  6. the Nokia 6230b Speaker Replacement: Schritt 6, Bild 1 von 1
    • Gently remove the case.
    • Careful! Do not bend the plastic tabs.
  7. the Nokia 6230b Speaker Replacement, Motherboard: Schritt 7, Bild 1 von 2 the Nokia 6230b Speaker Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
  8. the Nokia 6230b Speaker Replacement: Schritt 8, Bild 1 von 2 the Nokia 6230b Speaker Replacement: Schritt 8, Bild 2 von 2
    • Remove the panel that covers the motherboard.
    • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
  9. the Nokia 6230b Speaker Replacement: Schritt 9, Bild 1 von 1
    • Remove the LCD screen frame.
  10. the Nokia 6230b Speaker Replacement: Schritt 10, Bild 1 von 1
    • Remove the motherboard.
  11. the Nokia 6230b Speaker Replacement, Speaker: Schritt 11, Bild 1 von 1
    • Locate the speaker on the back of the removed panel.
  12. the Nokia 6230b Speaker Replacement: Schritt 12, Bild 1 von 1
    • Use nails to gently lift the speaker up; speaker may be slightly glued to the panel.
  13. the Nokia 6230b Speaker Replacement: Schritt 13, Bild 1 von 1
    • When the speaker is loose, gently lift the speaker out of the panel.
Abschluss
Job Jao
37 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-27, Regan Fall 2010 Mitglied von Cal Poly, Team 3-27, Regan Fall 2010
CPSU-REGAN-F10S3G27
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 17
Insgesamt: 2,786
