Einleitung
Use this guide to access the combined battery, RAM and hard drive compartment in a Fujitsu Lifebook UH572.
Was du brauchst
Remove the 6 black screws
To lift the cap use the opening tool.
There is a pit.
To reassemble your device, follow these instructions in reverse order. You have to press gently the cap in the reverse direction of the arrows, so the screws fit.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
