Zum Hauptinhalt wechseln
uAttend bn6000 Fingerprint Replacement
Was du brauchst
  1. uAttend bn6000 Fingerprint Replacement, Disassembly: Schritt 1, Bild 1 von 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Fingerprint Replacement: Schritt 2, Bild 1 von 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Fingerprint Replacement, Fingerprint: Schritt 3, Bild 1 von 3 uAttend bn6000 Fingerprint Replacement, Fingerprint: Schritt 3, Bild 2 von 3 uAttend bn6000 Fingerprint Replacement, Fingerprint: Schritt 3, Bild 3 von 3
    • Remove the two 7mm PH #1 screws from the fingerprint scanner mounting tab by rotating the screw driver counter clockwise, removing the screw from the housing completely.
    • Remove the fingerprint scanner assembly from the unit by lifting the scanner up and away from the unit housing.
  4. uAttend bn6000 Fingerprint Replacement: Schritt 4, Bild 1 von 3 uAttend bn6000 Fingerprint Replacement: Schritt 4, Bild 2 von 3 uAttend bn6000 Fingerprint Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the ZIF connector, by using your fingernail to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
Abschluss
To reassemble , follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 545
