Zum Hauptinhalt wechseln
uAttend bn6000 Speaker Replacement
Was du brauchst
  1. uAttend bn6000 Speaker Replacement, Disassembly: Schritt 1, Bild 1 von 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Remove the two 5mm PH #1 screws from the speaker assembly, by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
    • Remove the speaker assembly from the unit, by lifting the speaker up and away from the housing.
  4. uAttend bn6000 Speaker Replacement: Schritt 4, Bild 1 von 2 uAttend bn6000 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Remove the bundled cable carefully, by prying up on it with the plastic opening tool.
    • Carefully remove speaker from unit by pulling it up and away from housing.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 122
