Einleitung
Fan disassembly for cleaning or replacement.
Was du brauchst
Slide the latch on the right to the unlocked position.
Slide the latch on the left to the unlocked position.
Remove the battery pack from the slot.
With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
Now you can remove the bottom cover.
Start by locating the fan.
Unplug the power cable from the motherboard.
Remove the three screws that secure the fan.
Pry the fan up slightly with a flat blade screwdriver.
Lift the fan up to remove it.
100%
Jerry Wheeler hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
