Was du brauchst
Open the latch of the accumulator on the left side.
Open the battery latch on the right side.
Remove the accumulator by simultaneously holding the right-hand latch open.
Use the Philips screwdriver to remove the two screws at the bottom of the cover.
Lift the cover at the bottom right with the iFixit Opening Tool
Lift the cover at the bottom left with the iFixit Opening Tool
Finally, remove the cover to gain access to the most important components.
Locate the HDD disk.
Lift the plastic tab and pull the HDD hard drive out of its SATA connector.
Repeat the steps in reverse order to reassemble your device.
100%
Hier starten ›
