Why am I not getting any fuel pressure?
After replacing my fuel pump I am not getting any fuel pressure but the fuel pump is engaging. 2002-Dodge Ram 1500
Ist dies eine gute Frage?
did you bleed the fuel system when attaching the gas tank hose to the pump? Sometimes if there is a lot of air in the system it wont have enough suction to get the liquid pumping. If you didn't bleed the system when installing, you can unhook the gas tank hose from the pump and let the gas flow out of it, then re-attach it to the pump so it has liquid immediately available to push through the pump.
also did you replace the fuel filter?
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 784
