Zum Hauptinhalt wechseln
Veröffentlicht am 23. Oktober 2012 mit Core i5 oder Core i7 CPU, optional mit Fusion Drive
Fan always on - Mac mini 2012
Hi
I installed a Samsung 840 Pro into my Mac and now the fan stays on all the time at full speed. I have tried nearly everything including a SMC reset. I installed the temperature app and it shows the fan as 0 rpm. I reinstalled the old HDD and it's still the same. Any ideas? Help!
Thanks
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Double check your fan unit. Did you damage the cable?
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
Hey, The fan unit is ok - I've even replaced it!
The cable is not damaged.
I put the old HDD back in but now I'm thinking whether I should reset the SMC with the old HHD in - Haven't tried that.
I'm wondering whether this is a firmware compatibility issue?
von
The newer units require the special Apple HD with the internal thermal sensor (one for one). When replacing the HD for a SSD you need to install either a software app to control the fan or add an external thermal sensor to replace the one that was inside the HD. Frankly, we just add the SSD (dual drive setup) or we replace the HD for a SSHD unit (our current direction when we need to repair a mini).
von
And yes you likely need to reset the SMC after swapping the drives around. Sure, you could also check the firmware. The '12 units don't currently have any updates that I know of. Here's the Apple TN to double check what your system has: EFI and SMC firmware updates for Intel-based Macs.
von
Hi. Can you believe I this still hasn't been resolved. I'm on the edge of desperation! I put the original HDD back in and did a SMC and PRAM reset and the fan keeps running at full speed! I noticed that the fan socket left clip is broken, but this is just a clip to hold the plug in? The 4 fan connectors are perfectly fine.
Any ideas?
thanks
von
Ouch! it maybe the connection is not sound. You do need some pressure to hold the contacts firmly together. You could also have lifted the contact from the logic board so the connecter its self is bad. You'll need to repair the connector some how. I would recommend you find some one with the skills to work on SMT components and can replace the connector for you as this is not something I would even try my self (my eye's can't see this small stuff very well any more).
von
Antwort hinzufügen
Simon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 1,286
