Zum Hauptinhalt wechseln
Die Nachfolgeversion des Nintendos 3DS. Sie ist mit einem größeren Bildschirmen, längerer Akkulaufzeit, höherer Pixeldichte und verbesserten Design ausgestattet.
Frage geschlossen
Start and Select button replacement
So my start and select buttons cracked, no problem went and got a set from my local repair store for $5, now the problem I'm having is that when I install these new black start and select buttons, both like to get stuck down after I press them once and they don't go back up. My home button does not do this even with the replacement button. Any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I was actually just having the same problem, which is how I ended up stumbling upon your question. After a lot of frustration, I realized that the two little tabs on the rear of the button were being blocked from sliding all the way into their receptacles because a little bit of plastic had bent to block the opening. Once the openings were cleared the button worked properly again.
Hopefully this photo makes things a bit clearer: http://i.imgur.com/SuYXBe5.jpg
Just make sure there's nothing blocking the slots circled in red.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
THANK YOU SO MUCH, my god this was the most frustrating thing ever and now it's fixed thanks to you! THANK YOU. :O
von
Haha, I know the feeling. I nearly drove myself mad spending hours trying to reseat the buttons over and over again before I realized this.
von
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 3,191
