If the steam wand is leaking the valve o-rings are worn out. To replace the o-rings do the following:
1. Turn off the machine, unplug it, and allow any built up pressure to dissipate.
2. Remove the top cover by loosening the Phillips head screws.
3. Locate the steam handle hex screw on top of the black handle and loosen the screw, 5/64ths Allen wrench, I think. No need to completely remove it.
4. Rotate the handle and valve shaft out of the valve and out through the valve opening in the Barista. The valve shaft has two o-rings in grooves about 1/2 inch back from its end.
5. Take the valve shaft to your local hardware store and ask for replacement o-rings. They are 5/16x3/16x1/16. If you are nice the clerk might remove the old ones and replace them with the new ones. Allow them, removing and installing those o-rings is the hardest part of this job. Rub some hygenic silicon grease on the installed o-rings.
6. Reverse the above for assembly
7. Voila, you are ready to turn on your machine and have a coffee.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
5
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar
I have had the exact same problem and experience as Tanya - that is, leaking steam wand couple times over the years. Tech support walked me through the fix it in the past, but they no longer support. Henry H's brief response was enough to remind and motivate me, so I'm going to give it a try later this AM after machine cools down.
von Victor
