Zum Hauptinhalt wechseln
The Nikon D80 is a digital, 10.2 megapixel, single-lens camera that was released to the public in 2005. It is meant for digital photo-taking and filming.
28 Fragen Alle anzeigen
What is loose in my lens?
I don't know if there is a loose piece in my lens or in the camera body. When I tilt the camera, something loose obstructs one of the corners in the photograph.
What is it and can I fix it myself? It also seems to affect the color sensing as the photograph is faded and bright.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
What happens if you change lens? Sounds like the iris.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
To see where the problem is, select various f stops from 2.8- 32 (or whatever lens has) and watch the way the iris responds. Open to largest aperture and try rotating again to see whether any blades are falling out of position..
having tried this on my SLR camera you may need to leave the lens on to check the iris, to do that you may have to open the back of the camera, select B for exposure and whilst the shutter is down turn the aperture ring to watch the iris. Depends where your aperture ring is.
turn camera on, flash off, lens off. Select longest possible exposure time,either B or 1. Depress shutter and keep held down, look in where lens is meant to be,rotate camera to see what if anything is obstructing CCD. If yes then get back to us. I believe you should be able to fix most camera problems yourself, I'm not too familiar with your camera so this general advice. Your f-stops are prob on camera body but...
War diese Antwort hilfreich?
Bewertung 4
Had a similar issue recently and it turned out it was the UV protection filter. Something similar to an O-ring was just out of place making the glass tap against the metal. Got my Gerber and popped it back into place with the knife.
Bewertung 0
I think you have to check the lens of whether have a problem, or to relevant repair shops for advice and repair. Maybe you only change new camera gadgets. SPAM REMOVED
Bewertung 0
Antwort hinzufügen
k solis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 5,618
