Why won't it start?
My fa50 won't start. It gets good spark,gas,air,and air compression. Why won't it start?
Ist dies eine gute Frage?
the main jet needs to be cleaned in the carb .. take off the carb and clean it out
War diese Antwort hilfreich?
Sounds as if you are not getting fuel from the carburator into the cylinder correctly, if it were me, I would remove and then clean that carburator by use of some instructions from a repair manual.
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 32
Insgesamt: 3,334
4 Kommentare
What have you tried so far? Tried to squirt a bit of gas into the spark plug hole and try to start it, just to make sure it does get fuel?
von oldturkey03 Teilen
yes but dies once gas burnt
von jwhiteboy68 Teilen
jwhiteboy68, is this the same moped? Are you rodneylambert45? Just making sure we are dealing with the same issue here.
Here to, won't start normal ,does wel with startpilot at airfilter. When warm motor ,starts fine with kick only.
von Noel De Wulf Teilen
